Engine:
Designation: 1GR-FE
Fluid Change Interval (motor oil): 7,500 miles / every year – whichever comes first
* for hard use: 5,000 miles / every 6 months – whichever comes first
Classification (Engine Oil): SAE 0W-20 (U.S.); SAE 0W-20 -or- SAE 5W-20 (Canada)
Toyota Fluid (Engine Oil): Toyota part #: 002790WQTE01
Preferred Fluid (Engine Oil): Mobil 1 0W-20 Advanced Fuel Economy Full Synthetic
Capacity: 6.6 quarts
Fuel Tank Capacity: 23 gallons
Lowest Octane gasoline allowed: 87 (You must only use unleaded gasoline)
Highest Ethanol percentage allowed: 15% (E15)
Oil Filler Cap: Toyota part #: 1218031020 (hand tight)
Oil Filler Cap Gasket: Toyota part #: 9043037004
Oil Pan Drain Plug: Toyota part #: 9034112012 (thread size: M12-1.25) (socket size: 14mm; torque: 30 ft·lbf)
Oil Pan Drain Plug Gasket: Toyota part #: 9043012031
Oil Filter Cap Assembly: Toyota part #: 1565038020 (18 ft·lbf)
* Use the Motivx Tools Oil Filter Wrench for Toyota, Lexus, and Scion 2.0 To 5.7 Liter Engines with 64mm
Cartridge Style Oil Filter System for the Oil Filter Cap Assembly.
Oil Filter Element: Toyota part #: 04152YZZA5
Oil Filter Cap O-Ring (big): Toyota part #: 9030179006
Oil Filter Cap O-Ring (small): Toyota part #: 9672335028
Oil Filter Drain Plug: Toyota part #: 1564331050 (drive size: 3/8"; torque: 10 ft·lbf)
(5) Front Bumper Cover Lower bolts: Toyota part #: 9010906330 (socket size: 10mm; torque: 71 INCH-lbs)
(10) Under Cover Assembly/Sub & Seal bolts: Toyota part #: 9008011373 (socket size: 12mm; torque: 21 ft·lbf)
Drive / Serpentine Belt: Toyota part #: 90916A2015 / Bando 7PK2150
Oil Change Guide
