Originally Posted by texadelphia
Everything I've watched or read says to make sure the steering wheel is locked when replacing the rack bushings because you can mess up the steering wheel alignment if you don't. I can't wrap my head around how this would happen unless you disconnected the rag joint from the rack. It seems like as long as the rag joint isn't disconnected, and you just remove the rack mounting hardware, the position of the rack is tied to the position of the steering wheel. Am I missing something?
You're not missing anything, but I don't think you have enough room to press the bushings unless you disconnect the intermediate shaft from the rack.
