View Single Post
Old 05-13-2021, 04:42 PM
randy88fj62's Avatar
randy88fj62 randy88fj62 is offline
randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about
Run a test. Use two 14mm box end wrenches and remove your front driveshaft. then press your center diff lock. This will allow you to drive around in 2WD (aka rear wheel drive).
If the clunk is still there then you know it's not the front diff and tcase front output.
With the driveshaft out you can inspect and feel the u-joints for wear or excessive play. Bad front u-joint is usually accompanied by vibration when driving.
I find it hard to believe that the front differential and the front tcase output shaft bearing are both bad at the same time.
2008 4Runner Sport Edition 4.7 V8 4WD
1988 FJ62 Landcruiser
President LA County Trailcrew 4x4's
https://www.facebook.com/groups/Trailcrew4x4
randy88fj62 is offline   Reply With QuoteReply With Quote
