There are a lot of opinions out there. You can spend a lot of time reading threads here, tundra and taco sites, BITOG, youtube, etc.
I would say most people start to do drain and fills between 60k-120k.
The range of maintenance goes from a simple single drain n fill to a complete “flush” with pan drop and filter screen replacement.
Use your judgment based on whatever you choose is valid info.
My truck has had a pretty easy life but quite a bit of light off-road. I changed mine for the first time at 100k+.
I think after seeing the fluid and additional research I would start at 60k and do one or two drain n fills every 30k-45k.
