Originally Posted by G_Raw
Hey folks I get a random vibration at shift points. So basically at 1800 to 2500 rpms depending on my driving. It's happened since my lift. I've gone through 3 drive shafts. My stock 2wd was fine when i killed it but i put a different stock 2wd shaft in just to see if it would change. It didn't. I then completed my 4wd swap so now I'm running that driveline. I've pulled my rear third ( regeared) and put my stock third in and it only changes at what rpm and speeds the vibration is felt. I'm wondering if my rear axle is slightly off causing a wierd angle on the drive line that I can't see with my brakes eye. My axle appears centered to me but my pan hard isn't horizontal. Do i need to extend my pan hard more you think?
Looks like you have adjustable control arms too? Are they at stock length right now? If not have you tried adjusting them back to stock length?
