Real Name: Casey
Real Name: Casey
To me, it sounds like you are about as prepared as you can be. I don't have nearly 500k miles (will be just over 200k this summer), but it looks like you've done all appropriate maintenance and preparation. Just a couple thoughts, but I'm assuming you've already though of them judging by this pretty thorough list:
Grease all driveshaft zerks.
When was the radiator last replaced? Mine was leaking around 120k and then needed replaced again around 170k.
Random hoses like transmission cooler and pcv hoses all look good? My cooler lines (the rubber ones) were sweating recently so I replaced them, and pcv hose was cracked around the connection to the pcv valve so replaced it. I would just give all hoses under the hood a good look over (but again, judging by this list I am assuming you've already though of all of this).
Cheers to those miles though, I hope to wear the 500k badge of honor one day. Enjoy the trip!
2007 Limited V8 | 275/70/18 Falken Wildpeak AT3W | Spidertrax | 4xInnovations Weld On Sliders | Victory 4x4 Blitz Front Bumper | RCI Skids | TNF Rear Bumper | Smittybuilt Winch | KOYORAD Aluminum Radiator |OME 886 Front/Toytec Superflex HD Rear and OME Shocks/Struts | JBA High Caster UCA | Rebuilt LCA with Superpro bushings + Moog BJ | HCF Delete | Doug Thorley Shorty Headers | Magnaflow HFC | Gibson Catback | Rear Diff Breather Extension | 20" Spot/Flood | 9" Spots | DD SS3 Yellow Fogs | Amber Grill Lights | Fog Lights Anytime Mod
