Diode Dynamics just announced new kits available for the 5th gen 4Runner. If you're not familiar with Diode Dynamics, all of their lights use TIR (total internal reflection) optics. These optics are much more advanced than standard projectors or reflector cones. They're designed to capture all of the light leaving an LED chip and direct it off of a controlled surface, which reduces unneeded glare and increases intensity.
The first is an upper grill mounting kit for dual 6" bar driving beams. They are SAE J581 compliant, which means they are street legal to use as auxiliary high beams. This is the first bolt-on implementation I've seen for the 4Runner, and it makes a great option for people looking to get the most use out of their lights. They also have introduced stealth kits to mount their 30" bars in the lower grill (1 or 2).
I must say that I prefer my version using their 4000K SS3 pro lamps, but I had to design custom brackets in order to make them work..
The next product is ditch light brackets, to which you can use universally with any light, or option SS3 or SSC2 lights. Nothing ground-breaking here but their brackets are well-designed.
