Originally Posted by 3yakabucci3
Don't change anything.
Check the level, adjust if oil is needed, and just drive home and do it when you get there.
Engines are NOT as sensitive as our paranoid minds are.
This is good advice,
If you want, go to a Walmart buy the correct amount of oil, a drain pan, and a rachet to take out the drain plug.
Next morning drain the oil and refill with new oil. Shouldn't take more than 10 minurtes.
If you can't get underneath the car go to a shop that has a lift.
I have a 4runner. I can do a D/F without a jack.
You can buy a cheap jack at WM, Amazon or any auto parts store - and put it in the trunk.
Amazon.com: BIG RED T820014S Torin Hydraulic Trolley Service/Floor Jack with Blow Mold Carrying Storage Case, 1.5 Ton (3,000 lb) Capacity, Red: Automotive
