View Single Post
Old 05-22-2021, 10:17 PM
DenverAirport's Avatar
DenverAirport DenverAirport is offline
DenverAirport will become famous soon enough
Originally Posted by Brian. View Post
Your LOW temps, with the same rad, are higher than my Hottest down here in the hottest part of summer in Georgia. There's clearly an issue.
Start with the KISS, is there air in the cooling system? Not allowing the coolant to properly pressurize will lead to higher temps.
Haven't burped it recently but I will try this, especially since installing the new radiator. Could it really make this big of a difference in the temp?
99' SR5 "Highlander Edition" - 301k - 4WD, Factory rear locker, 2.5" Dobinsons IMS lift, SPC UCAs, CJV 9168 TR axles, 199mm TBU, Tom Wood's driveshaft, eimkeith PCK, Aluminum Koyorad, Ultragauge
97' Limited - 250k - Stolen & Found (and Sold) - 4WD, 3" Billstein 5100 lift with OME 881, 890 springs, Diff drop, Camburg UCA's, 231mm TBU, Tom Wood's driveshaft, eimkeith PCK, Champion radiator, Ultraguage
DenverAirport is offline   Reply With QuoteReply With Quote
