Hey there,
I do hear the relay switching in the kick panel on the passenger side. when i go to switch in 4WD and back out again. But No Illumination on the panel.
Thank you for the suggestion. If i can get the time i'll try your suggestion. Can you tell me if the Actuator is visible from under the Truck? I would like to see exactly what they are doing under there.
It's going back tomorrow.
The advisor also said something about the OEM parts from Toyota are long not available. so they had to go aftermarket.
Magnaflow, Rigid D Series 4" 50231/Rigid E Series 20" 12231 LED Bar ,K&N FIPK,3"Toytec ultimate, OEM 231MM brake upgrade, LED Interior upgrade,Bushwackers,Savage Rock Rails,Shock works front bumper,PERKINS NON PERFORMANCE REAR BUMPER 33'Duratracs,Kenwood DNX891HD JL Audio C5's
Currently 194K
Cheers
