Originally Posted by tathambenjamin
I had exactly your symptoms and previous owner did too even though he replaced head and headgasket in the course of ownership.
Has a new radiator, did multiple flushes of cooling system. As soon as I changed out my mevotech thermostat for OEM and it fixed instantly.
My next course of action was going to be changing the fan clutch- its about $100. Good timmy the toolman vid talking about symptoms, which are what we have described here, just like thermostat.
Good luck! If it were me I would just get the oem parts and take it to a guy locally and have them install before the trip. It would take me 4 times as long as a competent mechanic.
Thanks -- yeah like I mentioned in the post I already did the fan clutch and replaced the thermostat. I used that Timmy video for the fan clutch replacement, was a bit of an annoying task but got it done without a problem! Sadly neither of these things has done the trick so far.
99' SR5 "Highlander Edition" - 301k - 4WD, Factory rear locker, 2.5" Dobinsons IMS lift, SPC UCAs, CJV 9168 TR axles, 199mm TBU, Tom Wood's driveshaft, eimkeith PCK, Aluminum Koyorad, Ultragauge
97' Limited - 250k -
Stolen & Found (and Sold) - 4WD, 3" Billstein 5100 lift with OME 881, 890 springs, Diff drop, Camburg UCA's, 231mm TBU, Tom Wood's driveshaft, eimkeith PCK, Champion radiator, Ultraguage
