Originally Posted by Crob42
Prinsu no drill No silicone option. Use a gasket under a custom spacer, and two o rings on the bolt shank to stop water intrusion down the threads. All McMaster Carr stuff.
1/16 thick x 0.75 EPDM gasket
0.75 wide x 1.00 high Delrin spacer. Cut to 4.25 long
Drilled thru holes 35/64 inch diameter
1/8 buna o rings -203 size
This is great! What did you search for to find the derlin sheet? Also are the prinsu spacers 1” tall? I can’t get to mine to measure, but I love this idea.
