Originally Posted by Skykomish
Resurrecting an old thread... sadly this doesn't seem to be a thing with my 2019 ORP. Nothing in the manual or in Carista about shortening this interval. I had a look at the wiring diagram and sadly there's three separate signals for the front, rear, and hatch doors that go to two separate ECUs so adding an override switch doesn't seem like a good option here either. Has anyone found a solution for this?
This 20 minute interval is a fail safe for the battery. There seems to be no way to shorten the time. If you’ve changed your interior bulbs to LEDs they won’t draw that much power anyway.
If you want to keep the lights on longer, as when camping with the doors or hatch open, you can push a door frame button to re-trigger the 20 minute timer.
