Originally Posted by TX4Running
How did you get the ATF temperature? Thanks.
From the main menu screen, select “All Sensors”. There are two entries for ATF temperature. IIRC, it’s the first one that we care about “(AT) ATF temperature var. 1” (should be clear which one you want since the other entry will have no live data).
The screenshot I posted was of my customized dashboard. I played around with the layout, colors, fonts, and which sensor data I wanted to see. From the main menu screen, select “Dashboard”. Then select the gear icon to edit the screen.
