Bilstein 6112’s/5160’s. I’ve got some questions
Reviving this thread...
Got a Bilstein 6112/5160 Lift Kit. First... there is nothing wrong with it. All good, except...
I ordered the OME 898’s originally with the expectations of installing a 300lbs rear bumper. Bumper was put on hold. However, I have a winch and C4 bumper up front. The rake was BAD!
So, I put the original coils back in. But began to have a negative rake as I added gear in the cargo area. A few months later, I swapped out the originals for some 889’s, thinking it would level the rear. Well, no...I’m currently now 39.5” rear and 37” up front.
Terrible? Eh, but...
Suggestions for coil weight for the 6112’s up front (that fit over them and avoid shims) to give it a little lift? Even if it’s an inch?
Also, the future plan is to add dual battery set up and I’ve got JBA UCA’s if that helps you.
Trial Safe,
-JB
