Originally Posted by scratchhax
Looking for second, third, fourth and so on opinions.
I have a Victory 4x4 rear bumper with the adventure carriers. I also have a pair of rotopax 2 gallon cans. The cans fit perfectly behind the carriers and rest on the bumper (not suspended at all). There is the tiniest bit of rub between the can and the body.
Here is where I'm looking for opinions.
If I stick some thin rubber in there to stop metal on plastic friction, the only concern I'm left with is gas expanding the can itself. How much should I anticipate these things ballooning? The last thing I want to do is create a bomb behind my hatch, but lord these things fit perfectly.
I wouldn't do it, it sits too close. Even if you put foam or rubber back there there will always be vibration and rattling that will rub on the hatch and scuff the paint. The bumper is independent of the body and moves separately so any type of tire or driveline vibration, normal harmonic, and rattling/movement in the swing arm will just keep contacting the rear hatch. Plus as you said, Rotopax's are notorious for ballooning so you want room for it to expand. Put it on the outside of the tire or on the other swing arm.
