Originally Posted by aggrobot
If you read what I’m saying, i told him that the limited does not have a 2 speed transfer case, you lock the center diff for 4lo, I should have also specified 4hi. which is what you are saying. The limited is full-time AWD, there is no taking it out of that mode, only locking the center diff so the front and back turn at the same speed with even power distributed 50:50 front and back (when its unlocked, i believe its 40:60). Then yes, it can be geared down to 4lo. There’s nothing incorrect about the info ive provided, but I did overlook 4HI.
You are quite simply not familiar with the vehicle at all nor are you reading what I'm saying. There IS a two speed transfer case.
You can have 4 HI locked center diff and 4 LO locked center diff. You can also have all wheel drive mode (that's the default daily driver mode without the center diff locked). Locking the center diff does most certainly not put you automatically in 4 wheel LO.
