View Single Post
Old 06-06-2021, 03:02 PM
rightyouareken's Avatar
rightyouareken rightyouareken is offline
rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about
Originally Posted by SendInTheCavalry View Post
I think I figured it out... I might have had a mag mount antenna cable ran down the outside of the trunk seal following it down and to the bottom then up in the truck. I set it all back up, sprayed water (city pressure) all around the closed hatch. I had a helper in the truck with a flashlight. I was able to get one droplet on the bottom of the plastic hatch INSIDE (Past the seal). It was only literally one droplet... but Ive ran that antenna for a little better than a year and Ive been hunting the "smell" for at least 5 months.
Its been relatively dry in my area except the past 2 days it has rained at least 8 hours each day.
I cleaned everything up, dried the carpet pretty good. I was able to prop it up and shove a small desk fan to move air under the carpet. I completely removed the foam and carpet from the trunk. It will probably need another day to dry. I might empty a bottle of frebreez into it tomorrow and let it dry outside.
Since I was able to squeeze water from it I am guessing that was the point were water was coming it; it was by far the wettest. Best I can guess water was coming in, and like a pick up truck when I hit the brakes it would surge forward under the carpet?
Bummer. Dealing with stuff like that is why I ended up using a hood lip mount antenna for my ham radio. Running the wire through the firewall grommets seemed like a more weather proof option.
2020 4Runner Venture
2002 4Runner SR5 4WD (sold)
1998 BMW M3/4/5
rightyouareken is offline   Reply With QuoteReply With Quote
