Originally Posted by str8flexed
I have KDSS which I believe limits down travel so would you still recommend the "long travel shocks?" I am looking to have a 2.5-3" of front lift. I don't have "extended" anything else and have the coils "C59-352 - 200-240LBS heavy load front weight, 2.25-2.5" lift. 385/385mm, 18mm wire, 730LB"
I guess the question is, will the long travel shocks be smashed at full compression, or will the non long-travel shocks limit my extension at 2.5" of lift? Keeping in mind I have KDSS.
The two shocks in question:
IMS59-50700 - IMS Front Struts - suits 0-3" lift
IMS59-50574 - IMS Front Long Travel Struts - suits 2-3.5" lift
There's no problem running what I recommended to you. It's the rear that can't run the long travel shocks.
You're looking for 2.5-3" lift, which is why you should use the IMS59-50574
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons |
RCI |
Powerbrake |
Long Range Tanks |
Timbren |
Overland Vehicle Systems
Youtube Channel |
Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
