Originally Posted by inrebuttal2u
Okay 4Runner friends, I need some assistance.
I have the ABS, 4WD, and slip lights on the dash. The 4WD light is flashing. ABS and slip are constant.
I searched the forum and saw a discussion on ABS, 4WD, and slip indicator lights discussion. I havenÂ’t done a lift. I didnÂ’t replace lights with LEDs.
I have:
Changed the gas cap,
Replaced the whee speed indicators on LF and RF, and
Replaced the LF ABS wiring harness.
The OBD code I get is C1406, which is “open or short in front speed sensor LH circuit.”
Any ideas?
Have you done a zero point calibration?
Yaw Rate and Acceleration Sensor Zero Point Calibration
