View Single Post
Old 06-09-2021, 09:27 AM
Originally Posted by Tuco S. View Post
Terrible sign if that's the case.
My guess is these probably don't have much if any more built-in caster than oem UCAs. Their marketing literature is almost intentionally vague on the subject...."You can expect between +2.5 to +3.5 degrees of caster with a 2 inch lift." Seriously? +2.5 degrees is below the oem range for acceptable caster. You should be able to get +3.5 degrees caster if not more with oem UCAs on a 2" lift.
this...if i'm buying uppers i'm specifically checking for added castor to account for lift.
