you talking about the genesis dual battery kit? i think the genesis solution is good. good because practically all the work is done for you. i can see some of the cons though - its a lot of weight for that area, dual group 25s is not optimal if you are looking for longest run time, cost is higher than a diy system. i dont think its a bad kit though if you are not a diy type person.
Cement, RCI Skids & Sliders, Nitto Ridge Grappler, Northstar AGM, Goose Gear Plate, Dometic CFX 65W, Dometic Fridge Slide, BPF Molle Panel, Pedal Commander, Compustar, BlackVue, Diode Dynamics SS3
