Originally Posted by SendInTheCavalry
My only hang up on the BP51 right now is how it will ride with a relatively stock truck.. like I mentioned I have 150lbs in sliders and 100lbs Gobi rack. A few other odd and ends.. pump, slim recovery gear. Prob all together totals 50lbs.
And also I feel like +3” might be slightly aggressive for reasons you mentioned. Wish I could dial them down to 2”-2.5” and run them with oem UCAs.
Hopefully my “build” will be around this time next year. But I am starting to source things now. It’s kind of humorous that my two “contenders” Billy 6112/5160 with a 650lb spring, and BP51 are totally different in price and performance. But both equally great and I consider top tier in the respective category.
I think the OME can do 2.5". Just verify the spring. They are adjustable on both compression and rebound, front and rear, so you should be able to "dial it down" if needed. But it all starts with the spring rate. I think 600lb front is the sweet spot for most shocks. If OME is 650 that should do with softer settings and heavy tires. In my experience heavy tires want a stiffer suspension and vice-versa.
The 5160 has poor rep which is why I have had 3 aftermarket rear shocks but not the 5160. The 5100 will be fine with 6112 on 550s but there is no obvious fit for the 6112 on 650 which is why I am going directly to 8100 instead of experimenting further.
