View Single Post
Old 06-16-2021, 08:30 AM
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Originally Posted by 02_SE_Runner_DAD View Post
Thank you for that great info! What is the welder for? Does everything just bolts on to the 2wd? Really appreciate this info and thank you. I might have some more questions if you don't mind.
You have to move the transmission crossmember location for the 4wd transmission mount to be able to bolt up to the frame. You'll also need to cut out, transfer, and weld the section of body around the transmission and transfer case shifters. The body opening for the transmission and transfer case shifter are different.
