Originally Posted by 02_SE_Runner_DAD
Thank you for that great info! What is the welder for? Does everything just bolts on to the 2wd? Really appreciate this info and thank you. I might have some more questions if you don't mind.
As was already said:
Transmission crossmember has to be relocated (this pic is with the 2WD 4WD crossmembers in place while the 2WD trans was still installed):
Shifter holes (this is the 4WD holes traced out and the 2WD hole still there):
(this is the modified shifter area)
Check out the thread in in my signature for the whole story...
'99 4Runner SR5 Auto -
4WD swapped
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
