Got some requests for more details on the Aluminum Extrusion Frame platform:
The Frame (all parts from Tnutz.com):
Side Rails -
2 Series 10 EX-1020 1" x 2" Smooth T-Slotted Aluminum Extrusion, Length 38", no machining
Front Cross Rail -
1 Series 10 EX-1010-D 1" x 1" Smooth Tri-Slot T-Slotted Aluminum Extrusion, Length 37 11/16", Machining M6 X 1.0 X 25mm Deep Tap BOTH ENDS (this could be 1" x 2" if more strength is needed)
2 1-Hole Side Connectors EF-010 10 Series Blank End Fastener Clip (you will need to drill holes though the side of the Side Rails to tighten these)
2 Metric Button Head Socket Cap Screw M6 x 20mm
Middle Cross Rail -
1 Series 10 EX-1020 1" x 2" Smooth T-Slotted Aluminum Extrusion, Length 37 11/16", no machining
2 Series 10 6-Hole Plate Connectors - JP-010-F 10 Series 6 Hole Joining Plate (this allows you to move the middle Cross Rail forward and back a bit if needed to compensate for top panel clearances; in the original design/picture, this was a 4-Hole Plate)
12 Combo-010-E M6 Standard T-Nut & 12mm Button Head Cap Screw
Rear Cross Rail -
1 Series 10 EX-1020 1" x 2" Smooth T-Slotted Aluminum Extrusion, Length 37 11/16", Machining M6 X 1.0 X 25mm Deep Tap BOTH ENDS
2 2-Hole Side Connectors EFD-010 Double End Fastener Clip Only (you will need to drill holes though the side of the Side Rails to tighten these)
4 Metric Button Head Socket Cap Screw M6 x 20mm
The Feet:
Front Feet -
Toyota 4Runner Front Cargo Panel feet FROM SLIDING CARGO TRAY VERSION
58456-35010 Slide Assembly Mount Bracket
58457-35010 Slide Assembly Mount Bracket
These will replace the shorter feet from the sloped Front Cargo Panel of the non-sliding cargo tray version floor.
2 M6 Button Head Cap Screw 20mm min
[/url]
Rear Feet -
Connection to Side Rails -
2 CB-010-H 10 Series 8 Hole Inside Corner Bracket
8 Combo-010-E M6 Standard T-Nut & 12mm Button Head Cap Screw
Connection to Floor -
2 Steel L Framing Brackets (min 2" wide, min 3" high) from Home Depot/Lowes/HW Store (e.g. Simpson Strong-Tie 2 in. x 3-7/8 in. x 2-1/2 in. Galvanized Angle)
2 M8 Button Head Cap Screw 25mm min
4 M6 Bolts & Nuts to tie the two brackets together.
You will need to find the threaded nut locations for the Sliding Cargo Tray rear mounting points and drill down to them from the top of the floor, being careful not to strip out the threads. I found them by laying on the ground and looking up at the bottom of the floor; you will see welded-in nuts with RTV filling the insides. Scrape out the RTV and hit the middle with a punch so that you make a dimple in the floor sheetmetal, then drill down from the top using a small drill first, working up to the correct hole size.
Bolt the 8 Hole Inside Corner Bracket to the bottom of the side rails (flat extensions inward) and place the Steel Framing Brackets inside of them (feet facing inward). After aligning the Frame, some drilling will be required to mount the Steel Framing Brackets to the floor and to the 8 Hole Inside Corner Brackets.
The Top Panels:
The combined Top Panel length is 41". I cut them 43 1/4" wide to leave clearance on the sides in case I decided to cover them with carpet (a la Volvo). I made the rearmost panel 24" long and the forward panel 17" long, but you could allocate the length of the two panels any way you want. Each panel is held to the frame with 4 hinges from your local hardware store, e.g.
Everbilt 20257 2-1/2 in. Stainless Steel Narrow Utility Hinge Non-Removable Pin (Home Depot)
or
Everbilt 15397 2 in. Zinc Plated Narrow Utility Hinges (Home Depot)
You may have to "ovalize" the holes that mount to the Frame with a rattail file to get the correct hinge height and keep the Top Panels flush with the floor.
I used 1/4" Birch Plywood (which now seems to be metric, so it is actually thinner), so I ended-up reinforcing the larger panel with some leftover scrap plywood and some aluminum channel I had lying around.
16 Combo-010-E M6 Standard T-Nut & 12mm Button Head Cap Screw (to mount the hinges to the rails)
16 M6 x 14mm Flat-Head Screws and Nyloc Nuts (to mount hinges to the Top Panels - SCREW LENGTH WILL BE DEPENDENT UPON PANEL THICKNESS)
Notes:
Remove rear threshold trim, cargo area carpet, front cargo tie-downs, front cargo panel, and styrofoam under pad. Information on how to do this is in the first part of this post:
5th Gen Sliding cargo tray Install - Pics/Steps
Unbolt the front cargo panel brackets from the floor and replace them with the factory Slide Assembly Mount Brackets with the "wings" pointing outward.
After you have assembled the frame and established it's location in the cargo area, you will need to locate and drill 6mm access holes down through the top of the inner channel of each side rail so that you can slide 6mm button head cap screws into the channels (which will mate to the captive nuts of the Slide Assembly Mount Brackets) and tighten them through the access holes. Wads of paper or dollops of RTV can be used to keep these screws in place.
I reused the front cargo tie-downs on the very front of the forward floor, passing the bolt through the outer hinge plate for strength.
The rest of the cargo tie-downs/floor retainers are M6 x 11.2 mm SS Eye Bolts (available from Amazon). If you make the floor panels out of a thicker material, you will need to find longer Eye Bolts.
Amazon.com: Glarks 36Pcs 304 Stainless Steel M6 Male Thread Machinery Shoulder Lifting Ring Eye Bolt with Lock Nuts/Lock Washers/Flat Washers Set: Home Improvement
The stronger 6m channel nuts (DB-010 Drop-In T-Nut w/ Spring Ball, M6 x 1.0) should be used to anchor these. On my floor, they are retained to the panels using 1/4" Pushnut Bolt Retainers.
