Originally Posted by Stephencovar
Hey! Thank you so much for your response. How’s the ride quality on the Fox 2.5 DSC?
By definition, you cannot get the same ride quality from a velocity-sensitive shock as from a position sensitive shock unless you valve it so softly that it becomes just a pricey ornament.
You cannot expect to move away from a more sophisticated design (stock internal bypass Fox) to a less sophisticated one (FOX 2.5 DSC, Icon 2.5 non-bypass) and gain in ride quality without butchering the performance. You can gain in performance though.
You can get it all, if you go for bigger position sensitive shocks such as Bilstein 8112/8100 or a custom other brand setup and you keep your lift within reason.
But first, you should drive your current setup in the desert and in rocks to see what, if anything, you really want/need.
