Originally Posted by Bkt4runner
Here is the first run. It has a black paint finish that wasn't powder-coated and uses plastic dust boots.
For the 2nd one I will do it much better. I will add media blasting and powder-coating to the body in a black finish, source higher quality internal seals that is better than OEM and then find a silicone dust boot. I found out that Toyota will no longer be selling the steering rack rebuild kit for the 4th gen 4Runner anymore so that means someone has to build a replacement kit.
Can you provide the Energy Suspension part number for those steering rack bushings? Also, is there anything specific you need to do to install them? I've heard that the ES bushings require the sleeves left in when working with them, although that might just be for suspension and not rack bushings...
