Originally Posted by justinbuckley
Hey all,
Just purchased the Eibach Pro-Truck lift kit for my 2006 SR5 4WD.
PRO-TRUCK LIFT SYSTEM (Stage 1) - TOYOTA 4Runner Base
Wanted to check with others to see what additional work/parts I may want to perform/replace while I'm at it. Truck is a weekend driver, used mostly on paved and gravel/forest service roads - some occasional harder trails but I wouldn't call it wheeling.
Thanks in advance for any advice!
I did this setup a month ago. Just that I used T1/T12 instead of eibach coils. I also did a diff drop just in case. My CV looks nice and straight now with my 2.25-2.5"(after settle) lift in front on my 07 v6 4x4.
And yeah, be careful of front ABS line if you are planning to unbolt the UCA ball joint during install and careful about rear brake line while stretching the rear axle during the rear coil install.
