Originally Posted by K-D-Runner
Hey man I was in the same boat but I went ahead and pulled the trigger on 5 KO2's in this size, been waiting weeks for discount tire to get them in though cause they only had 2 in stock but once they're in I'll post things up. I have a dobinsons IMS lift with probably about 3.5in in the front and 4.5-5in in the rear, SPC UCA's, no front sway bar, extended travel rear with 2in bumpstop drops, super pro extended control arms, and most importantly a 1in body lift. I got my spare mounted up and used it for test fitting and cutting. I then have a bmc, cut away inner fender, hammered the pinch weld, trimmer the front bumper slightly and might have to cut the rear bumper a little. Probably enough to even fit 35s but I wanted to be able to go full stuff without rubbing things like crazy. This size is big enough though where you either gotta be willing to cut a lot or have the perfect setup, or just be a mall crawler and never flex things out ahahah. Pm if you want some photos of things so far, I'll start a build thread eventually.
Right on! I'd really love to see the final product. I'm already committed to getting a BMC and pinch weld mod, I already got a quote from a local fabricator that will bang out both. I also already have a 3/2 lift with SPC uppers, but was looking at Dobinsons to get an extra inch or two, and coincidentally was just looking at that Toytec 1" body lift. We're in the same boat, lol. Although I'm considering the Yokohama Geolandar MT's or Nitto Ridge Grapplers in that size. Keep us posted!
EDIT: BTW which DObinsons springs did you end up going with?
