Originally Posted by dawudih
FYI, I just picked up an oem Toyota air filter for my 2015 Trail & noticed it was about half the depth of the previous ones I've used. The model number is the same (YZZ....) & the parts guy verified this. He went in the back & said there was a memo stating Toyota went from 35mm to 20mm depth. Just found it interesting is all.
That’s strange.
You’re referring to the engine air filter, not the cabin air filter, right?
The old engine air filter version with the foam pre-filter (as delivered on a new vehicle P/N 17801-38051) is about 55mm if you measure from the rubber gasket to the end of the foam. The other version without the foam (US P/N 17801-YZZ13) is about 5mm shorter.
Do you have a photo of yours?
