Originally Posted by mtbtim
My cooling system is sound. Fan clutch, radiator, and thermostat have all been replaced. I do plan on re-gearing to 4:88 which I know will help. I’m wondering what else I might be able to do. I’ve heard the Champion radiator might allow me to run cooler. If you have any suggestions, I’d appreciate reading them.
Thanks!
I'd still suspect the cooling system just a bit - the radiator cap. If not new and OEM, change it out.
I had slight overheating issues when I had a weak radiator cap - it got up in the 210*F range in ~105*F heat with a medium load (32's, armor, 3 dudes w/ backpacking gear) on long hills. It was always fine around town, in traffic or on regular freeways (rock solid at 191*F). After replacing the cap, no issues with the same or higher load in harsher conditions. I already had a new radiator, new water pump, new thermostat and coolant (all OEM).
The OEM cooling system is incredibly good, I think it might be as simple as the radiator cap.
Edit: PS. I always run about 40% coolant / 60% water - it has been ok down to as low as -10*F temps on my Subaru, and I'd assume the 4Runner would be fine that way too.
'99 4Runner SR5 Auto -
4WD swapped
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
