Originally Posted by boulder
I had this same problem on my 2003 4runner, I think the accumulator was not holding pressure so the motor kept running off and on. I got on ebay and bouth the accumulator, pump and motor assembly for 350 bucks. Installed it myself and now works like it should. Motor only comes on if you apply the brakes for a long period. once pressure is built and you do not use the brake it should never turn on. I got the rebuilt motor with the used accumulator from ebay.
did the same thing, but my reman'd unit was bad. sent it back no problem. hoping the new one will fix the problem.
