"off-road a few times a year"
Honestly that's too generic to tell. Judging from the wording and the picture, looks like a solid overlanding setup is what you are after. Maybe throw Dobinsons into the mix, they have a variety of shocks from twin tubes to monotubes to monotubes with resi and adjusters. Given your desired height, Eibach is out; you cannot really run their rear shock with a 2" lift and expect good results; it is a short shock.
Btw, I am not sure 5100s will play well with stiff OME springs. They are designed to work with soft stock springs.
