January 2021
-I used these from Clazzio, since I have their leather seat covers.
Clazzio Leather Seat Covers - Heated Seats Page
-Here is the link I initially followed to tie into a 25A fuse in the engine bay.
non-OEM Seat Heater with Factory Fuse - How To
-I wound up using the green wire in the driver kick panel that ties into the 25A fuse into the engine compartment labeled as seat heaters. Green wire ends at the IC4 and goes no further.
-Did the Relay swap from the Tow to the IG to give it power. Bought a couple relays to fill the tow spot. Found a pair pretty cheap on eBay, I’ll have an extra when I need it…… IF I can find it at the time lol.
-Here’s my fuse box after I filled the missing IG relay
-Pulled the seats out and the Clazzio seat covers back to insert the heating pads.
-Drilled out the back side of the center console to add switches. I put them towards both edges which turned out to have clearance issues with the main console support underneath. Had to get after if with my cordless Dremel.
-Ran the wires and mounted the Relay for the kit under each seat.
-Definitely makes a huge difference as the leather Clazzio covers sure are cold in the morning in the winter! Went ahead and drilled a spot for my future “armed” power button for my push LED buttons in center console for when the dogs step on them and we’re not aware.
My build thread https://www.toyota-4runner.org/4th-g...ml#post3520544
2008 Titanium Metallic 4WD 4Runner V6 SR5| Satoshi Grille mod|17x8 Level 8 MK6 wheels, 275/70/17" Falken Wildpeak tires| Front-Bilstein 5100's set at 0 with ToyTec branded Eibach silver springs and 1/2" ToyTec spacer driver side, 1/4" ToyTec spacer passenger|Front Diff. drop spacer kit|sway bar relocate kit| Rear-Fox 2.0Resi and ToyTec superflex black springs|Tyger Bull bar with LED's/Lund HX tube side steps
2021 Subaru Crosstrek Limited in Crystal White Pearl
