Originally Posted by CajunMikeR
Not sure if the overall width measurements would work, but have you considered the power steering rack out of a Mustang 2? They're fairly common and used in lots of hotrod projects, so it may be easy to adapt for your application.
Haven't heard about those, looks like the lines are routed to the front side. And a few ratio options too.
It gets mounted completely differently though, and looks like usually to the front of a crossmember, it might be tricky to mount it to the rear of a crossmember like in the Celica, and the input shaft needs to be pointing pretty much straight up at a pretty specific angle. I'll look at some other common rack swaps though and see if any will work.
2005 4R Sport 4WD
"The last of the V8s!" - Custom TIG'd SS Dual Exhaust - King 2.5" +2 LT. - ARB Front & Rear - 37's - Dana 60 -
Build Thread
1977 Celica Liftback - LFX Swap -
Build Thread
