Originally Posted by aemravan
Never had an issue on my '03... not with a scanner nor with my regularly used Torque app/bluetooth OBII adapter I use to connect it to..
Yeah, I can't believe I've had such bad luck. I found good threads here explaining why it happens. If the scanner does not try can bus first, it won't cause the problem. Every one of mine tries can bus (new trucks) before ISO 9141 (older trucks) or whatever it is called. Every time I have to do the zero point calibration reset routine.
One cause & fix for "VSC TRAC" & "VSC OFF" lights, Zero Point Calibration
