Originally Posted by Kamalani Mahie
I'm curious to know what the actual temp got to. I'm assuming you didn't have a scangauge going at the time so you don't know the temperature? I've been loaded down before and climbing mountains in 100 degrees but never got a high temp warning. Trans temp has gotten up into the 230s and 240s. Since you're light did come on, I would check the tranny fluid to see if it's still good. Once that fluid gets too hot it will break down and not provide the proper cooling/lubricating necessary which will result in future transmission damage and eventually failure. Get it checked ASAP.
Also one thing to note is you should climb at a constant speed in one gear. I do not use "D". Usually it's S4 or S3. That will keep the tranny from hunting and keep the torque converter locked more resulting in less heat buildup in the tranny.
Great stuff here. Thanks.
Will look into scangauge. You have any recommendations?
