View Single Post
Old 06-30-2021, 12:51 AM
Skulking Skulking is offline
Skulking is a jewel in the rough Skulking is a jewel in the rough Skulking is a jewel in the rough
Originally Posted by domhanna View Post
Where did you find OEM springs that cheap, I'm looking at $625 for all four springs from my nearest dealership?
And where did you buy the Bilstiens from I found 4600s on shock surplus @ $333 for all four.
OME (Old Man Emu) is a manufacturer with their own line of springs primarily for lifted Toyotas. It can definitely cause confusion. If you are looking to keep things stock, KYB Gas-a-just or Bilstein 4600's are generally the recommended aftermarket shocks. As far as springs go, you almost certainly don't need to replace the fronts, but are more likely to need to replace the rears as they do tend to sag.
As others have said, the typical recommendation is to go OEM only for lower ball joints as a failure is catastrophic. I would stay away from that kit.
Skulking is offline   Reply With QuoteReply With Quote
