Originally Posted by Lexington
Ok I basically understand what you’re saying. I’ll talk to my mechanic or the 4x4 shop about this. So you’re suggesting to go the fuse route vs a light switch left of the steering wheel then, correct? Also, I don’t have a KDSS. So what is the better option, use a fuse tap or use a empty fuse box.
I also contacted Morimoto to ask what is the max power draw the Bluetooth controller can pull. My guess it’s probably not too much but just want to make sure.
Anyway, thanks for your post. It was helpful.
You would just use the fuse tap in an empty fuse slot in the fuse box.
