Originally Posted by Rottwagon
Yakima Mighty Mounts 23H. They work perfectly on the stock crossbars. The rack tubes are 1.75" OD. Many clamps and mounts can be found to fit the tubes if you do a quick search. There will be a clamp solution for anything you want to mount to the tubes.
Thanks, I just ordered some based on reading this. I didn’t want to drill through the bars to install rivet nuts, so this should be a great option.
