Grab a cable and techstream off ebay to read the codes.
On a 2011 at least, if you have a CEL of any type, it will say MTS Unavailable, VSC, and the ADD will not engage, so 4wd does not work.
Most likely is a stretched ABS wire, I have seen more threads on that than probably anything besides wheel balance issues. If you don't completely remove the ABS wire and disconnect a ball joint, there is a high probability you will stretch a wire. Usually it is damaged in a way that can't be seen, you would need a multimeter.
