Originally Posted by AuSeeker
If you find on a visual inspection that the frame seems to have 15% to 20% bad rust issues/spots it more than likely has twice to 3 times that much rust because many times the rust starts or is on the insides of the frame rails where you can't see it until it rust through to the outside of the frame!
Tap on all the good areas of the frame, every square inch with a hammer, if it doesn't sound solid then that spot has bad rust on the inside of the frame which will soon come through the frame.
It’s hard to say the percentage as it is pretty spotty on the frame. I knocked around with my hand and most of it felt or sounded solid. It’s flaking quite a bit so I’m wondering if this hasn’t been treated with something before I bought it. Either way, not what I wanted to see after just buying it : (
