Join us now!
Remember Me?
FAQ
Social Groups
Calendar
Photo Albums
FAQ
Social Groups
Calendar
Mark Forums Read
Toyota 4Runner Forum - Largest 4Runner Forum
Forums
Thread
DIY: Tubbing the firewall to clear 35" tires (3G4R)
View Single Post
07-11-2021, 06:17 PM
willhaman21
Real Name: Will
willhaman21
Real Name: Will
(Continued)
15) Get out your BFH. Hammer the inner fender below the battery box. You could cut this out and patch with new metal if you are so inclined, but I felt like it wasn't worth the extra work. Hammer 'til she clears.
16) Check clearances again. Here's where everything sits at full bump.
The SPC upper control arms hit the inner fender above the coil tower at full bump. This is the mechanical limit point of the suspension's uptravel.
I removed the ABS line bracket, and zip tied the ABS wire to the UCA instead. This eliminated the possibility of the wire getting pinched between the UCA and the inner fender.
Here's where the lower control arm sat at full bump. ~ 5/8" clearance beneath the bump pad.
Here's where the cutout ended up at this point.
IMPORTANT!
You will know you have cut enough when the tire fully clears the sheet metal from lock to lock of the steering wheel while at full suspension bump. Note that it will rub the frame at the back of the tire, this is the mechanical limit of the big tires unless you wish to notch the frame.
Weight reduction...?
View from below.
Mocked the fender back on just to see what it looked like.
Final shape.
(Continued)
06:54 PM
willhaman21
View Public Profile
Find More Posts by willhaman21
willhaman21
View Public Profile
Popular Tags
3rd
4runner
4th
5th
air
area
axle
back
battery
black
brake
bumper
car
door
engine
fluid
front
fuel
gen
good
head
issue
i’m
key
kit
led
lift
light
lights
limited
miles
noise
oem
oil
part
parts
power
pro
pump
rack
rear
replace
replaced
replacement
roof
running
sensor
set
shocks
side
sr5
start
steering
stock
switch
system
time
tire
tires
toyota
transmission
trd
truck
turn
unit
vehicle
wheel
wheels
work
wtb
» Follow Us!!!
» Log in
User Name:
Password:
Remember Me?
Not a member yet?
Register Now!
» T4R Sponsors
Become a Sponsor
Powered by
vBadvanced
CMPS v3.2.2
06:20 PM
Search Engine Optimisation provided by
DragonByte SEO (Pro)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
Advanced User Tagging (Lite)
***This site is an unofficial Toyota site, and is not officially endorsed, supported, authorized by or affiliated with Toyota. All company, product, or service names references in this web site are used for identification purposes only and may be trademarks of their respective owners. The Toyota name, marks, designs and logos, as well as Toyota model names, are registered trademarks of Toyota Motor Corporation***Ad Management plugin by
RedTyger
Toyota - 4Runner . org Forum
