Notices
View Single Post
Old 07-14-2021, 09:25 AM
jerbrun0515's Avatar
jerbrun0515 jerbrun0515 is offline
jerbrun0515 will become famous soon enough
FS, 1999 SR5, Clean w/ 5spd and e-locker, Overland Build, Grand Rapids, MI - $11k OBO
**SOLD**
**MORE PICS AVAILABLE ON REQUEST**
The day I never thought would come has arrived. I’m putting my beloved 1999 up for sale. I’m still in the T4R game though. A 5th gen just fits my family of 5 a little better.
So here she is. 1999 SR5 w/ 5 speed manual and factory e-locker in Desert Dune Metallic. I’m the third owner and it has 147,000 miles on it.
The truck is in extremely good shape - inside and out. It runs and drives perfectly. I’ve meticulously cleaned and maintained it. There is no rust on the body, and very minor surface rust on the frame/underbody. Having been in Michigan since 2013 (when the second owner brought it from Arizona), it is in amazing shape underneath. The previous owner immediately started treating it with Fluid Film and I have kept that up since I’ve had it. In case you don’t know Fluid Film, the way it works is it forms a non-hardening coating and when dust naturally clings to it, it forms what I like to call a “grime barrier” that keeps the rust at bay. So looking underneath it’s dirty, but there is only minor surface rust here and there. The steel rear bumper is past due for a sandblast and new powdercoat so that has some surface rust since it didn’t get Fluid Film quite so much.
The original interior and upholstery is in very good condition, but to further protect it, it has a full set of fitted Wet Okole seat covers that are a waterproof neoprene.
Here’s a notable list of updates and modifications
  • Wet Okole Seat Covers for 1st and 2nd rows w/ heated driver and passenger, waterproof
  • ICON Stage 2 Front Coilovers
  • ICON tubular upper control arms
  • ICON 2" rear shocks
  • OME 890 rear springs
  • Shrockworks front winch bumper w/ PIAA fog lights
  • Savage Off-road rear bumper with swing out tire carrier
  • 5x TRD Pro 5th Gen 4Runner OEM Toyota wheels
  • 5x BFG KO2 255/75R17 tires ~22,000 miles
  • 231mm 13WL Tundra brake upgrade
  • Pioneer head unit w/ bluetooth & hands-free microphone
  • Uniden Pro 520XL CB radio w/ 5' Firestick antenna
  • Airaid cold air intake
  • “Blue Wire Mod” - bypasses the restriction of having to be in 4-low in order to engage the e-locker. Still have to be below 5 mph. Retrofit Electric Locker
  • Rad Rubber Designs engine bay mud shields
  • Sherpa Equipment Co. Matterhorn full-length roof rack
  • PanaVise inDash phone mount base
  • Satoshi Grill
  • Overland Custom Design HD sway bar end links (rears installed and fronts ready to be installed)
I will be taking the winch and KC lights off of it before selling.
Ever since being bought by the second owner, a detailed maintenance log has been kept for this truck.
Noteworthy Maintenance
08-21-13 87175 Oil Change
08-21-13 87175 Engine Air Filter
08-21-13 87175 Timing Belt
08-21-13 87175 Accessory & AC Belts
08-21-13 87175 Clutch Assembly & Throwout Bearing
08-21-13 87175 Re-surface Flywheel
10-15-13 89550 Re-Paint hood & roof
11-08-13 89800 Rear Hatch Lift Struts
11-10-13 90000 Wiper Blades
04-05-14 90959 Oil change
09-01-14 91623 Rear Wiper Blade
09-18-14 94700 Trans & transfer case fluid change
11-19-14 95555 Oil Change
11-19-14 95555 Replaced Clutch Pedal Clevis/Pin
12-28-14 96008 Front & Rear Diff Fluid Change
01-05-15 96012 Tundra Brake Upgrade
01-05-15 96012 Braided SS Brake lines
11-15-15 99789 Oil & Filter Change
12-30-15 100538 Lower Ball Joints Replaced
12-30-15 100538 Front Sway Bar End Links
12-30-15 100538 Clutch Pedal Bracket Replacement
12-30-15 100538 Headlight Bulbs
12-30-15 100538 Rebuilt/Re-sealed headlights
07-22-16 106000 Oil Change
09-03-16 106600 F/R Diff/Trans/XferFluid Change
11-20-17 112500 Steering Rack Bushings
11-20-17 112500 Driveshaft rear u-joint rebuild
11-20-17 112500 Oil & Filter change
12-15-18 116500 Accessory & AC Belts
12-15-18 116500 Lower Control Arm Bushings
12-15-18 116500 Steering Rack, inner & outer tie rods
6/1/2019 118000 Battery
6/1/2019 118000 Front Upper Ball Joints
----------- Change of owner
7/30/2019 123145 Oil Change
1/2/2020 131680 Oil Change
5/4/2020 135899 Coilovers and UCA clean, grease, and pressure check; F/R Diff fluid; Rear Diff breather extension installed
5/8/2020 136000 Replaced L+R full headlight assemblies with factory originals (salvage donor); This was due to failure of the seals done by previous owner
5/29/2020 136000 Rebooted L+R CV axles and replaced L+R axle/diff oil seals; Front diff fluid changed
9/4/2020 13?000 Rear Sway Bar End Links
10/20/2020 141211 Valve Cover gaskets, Throttle Body gasket, Intake Plenum gaskets
10/23/2020 141211 Oil Change
This truck has been used like a 4Runner is intended, but not abused as you can tell. Here is a short list of things I would want to know if I was buying it.
  • There are minor paint chips and pinstriping on the body. Most of them are extremely hard to find.
  • There are a couple shallow dents on the front edge of the hood. You have to look for them, but the story is unknown from the previous owner.
  • One of the PIAA fog lights original to the Shrockworks front bumper does not currently work. I’ve narrowed it down to a loose connection somewhere in the light housing itself. In the long run I planned on swapping the PIAA’s out for some sort of LED alternative.
  • The windshield has had a crack along the bottom of it since I bought it. It was never in my line of sight so I never bothered with getting it replaced.
  • Previous owner coated the black plastic fender flares with Plasti dip. Over time that coating has flaked and peeled. Plastic is sound and not faded underneath, but my plan for when I was bored some day was to pressure wash them off and re-apply Plasti dip.
FS, 1999 SR5, Clean w/ 5spd and e-locker, Overland Build, Grand Rapids, MI - k OBO-20210629_211522-jpg  FS, 1999 SR5, Clean w/ 5spd and e-locker, Overland Build, Grand Rapids, MI - k OBO-20210629_211532-jpg
jerbrun0515 is offline   Reply With QuoteReply With Quote
