Originally Posted by Dahlken
It still needs the lower bushings, and having the LCAs off I will be able to see if there is anything bent or out of whack. Short of that all that's left is bent knuckle or frame bent/twisted.
The vastness of this incredible place puts most of us much further away than most of the lower 48 realize until you see it for yourself! But well worth it!
I'll be tearing the front end completely apart after work today and see what I end up with. The sway bar will definitely be removed for atleast the rest of our summer here. As for the UBJ/knuckle, at full droop the passenger side does set down onto the coil. But not on the driver side. I'll have a real good look at it tonight and see what I come up with. Hopefully its something stupid and easy to sort.
good luck and keep us posted.
Yes it is incredible up here, the vastness and beauty
...but for a car guy it can be a hassle , at least in fairbanks.
