Originally Posted by Bagels
I could not find one but once you get started you see what needs to be done. Basically just trim out the inner portion of the stock grill and then slowly remove portions of the Tacoma grill until it fits snug in place.
Then I drilled holes in the grill insert and stock grill to zip tie them together. Two on each side where the two grills touch. Covered the zip ties up with two part plastic epoxy and then put epoxy on all other contact surfaces. A little black paint on places the epoxy is viable and reinstall!
Do you mind posting what parts are needed for this grill swap? Thanks for posting.
Could you post some pics of the back side of the grill?
