Originally Posted by Thirty4
Thanks for the clarification. It is a TRD PRO wheel for sure. I really appreciate all of the help. In this case, if I bought an aftermarket wheel with a zero offset, just so that I am understanding this, that would move the wheel out…..by just a little bit of course correct? So, an aftermarket wheel with a negative offset, like -10, could move the wheel out even more correct? Just making sure I am grasping this.
That is correct; the lower the number, the further it will push out away from the hub.
With that said, you have to take an aftermarket wheel’s width into consideration as well. Almost all aftermarket wheels you typically see on a 4runner will be wider than the trd pro’s 7 inches.
