He’s a competent truck owner and had everything tightened correctly. Vibrations went away when he removed the spacers. Who knows.
What is the recommended tire size for a 17x8.5 tire?
Also, if you run a 0 offset 8.5 wide wheel with the recommended tire, will that require any body modifications?
2017 Toyota 4Runner TRD Pro Cement Gray - OE blackout badges, Innovativ HIDs, OE LED fogs, AJT, black TRD shifter, 33inch light bar, K&N, CanvasBack, Toytec 2 inch lift, 34 inch tires, 2021 TRDP wheels, URD
