Dang, that is substantial. By the time it's cut back to weldable metal it will be quite large. My holes in that area were way smaller so I cut back the metal and welded in plates, I have a thread on it here. Before you do any more I suggest you check the rest of the frame closely. Check the bottom side of the frame under where your feet are when driving, the area the fuel tank straps bolt to and the front crossmember where the tow points are. You may find there's more cancer than you thought.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
